I am looking to both 'Enable ProjectWise Drive' and turn on 'Sync Work Area Participants' as part of our new CONNECTED project creation process. I am looking for Powershell options. Has anyone come up with a solution?
Dave
Not sure if there is a way to 'Enable ProjectWise Drive'. Maybe Dave Brumbaugh can offer some insight. He is the wizard behind the curtain.
Have you looked at the Set-PWWorkAreaConnectionUserSync cmdlet?
Thanks Brian. I will go back and have another look, make sure my version is current. Drive is so new it may not be available...but will certainly be needed.
d
Hey Brian. I used the Set-PWWorkAreaConnectionUserSync cmdlet and it's actually enabling Drive but not the participants....opposite to what I thought would happen! Talk about confused!
Yeah, that seems odd. Hopefully someone else can chime in on this one.
