Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Archive Versions
    • Sign In
    • State Not Answered
    • Replies 8 replies
    • Subscribers 67 subscribers
    • Views 1005 views
    • Users 0 members are here
    Archive Versions
    Stephen Herrick
    Offline Stephen Herrick over 2 years ago
    Requesting the ability for cmdlets, Export-PWDocumentsToArchive and Import-PWDocumentsFromArchive to archive document versions. Unless i am missing something obvious
    the purpose is that i am importing active projects located in several different datasources into one, Archive does a good job, but ideally i need the versions as well
    Is there another option?
    Stephen
    • Sign in to reply
    • Cancel
    • Dan Williams
      0 Offline Dan Williams Wed, Apr 21 2021 5:42 PM
      Stephen Herrick,
      I will add "version support" for the Archive Cmdlets onto my "ToDo" list, but no timeline or commitment.
      In the meantime, you might want to take a look at these two Cmdlets to see if you can make them work for your needs:
      • Export-PWDocuments
      • Import-PWDocumentsBySpreadsheet
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Stephen Herrick
      0 Offline Stephen Herrick Wed, Apr 21 2021 5:53 PM in reply to Dan Williams
      Thanks Dan,
      i had tried those, but it doesnt bring in the user like the arcjive does,
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Wed, Apr 21 2021 7:50 PM
      Steve, are you finding export to archive slow? I've been playing around with how we want to export archives and I thought it wasn't really usable with data sets of tens of thousands of files.
      (Dan - when you get around to looking at this one, it also needs reporting of what individual files fail)
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Brian Flaherty
      0 Offline Brian Flaherty Wed, Apr 21 2021 11:52 PM
      Are you using a saved search to specify the files to export? If so, ensure the document versions are included. Otherwise, versions should be included by default.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Stephen Herrick
      0 Offline Stephen Herrick Thu, Apr 22 2021 8:11 AM in reply to Brian Flaherty
      Brian,
      i am not using a saved search, i use the browser and select the project i want to Archive,
      so your saying if that i use a saved search with the version option, the archive will include versions?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
