I've been combing through the list of commandlets and can't seem to find one for defining a connection between a PW work area and PW connect project.
I.E.
Apologies in advance if I'm missing the obvious!
Take a look at the Set-PWConnectedProjectAssociation cmdlet. It may do what you need.
Hi Brian. That's the command for associating the connect project to the work area. I'm talking the actual PW Web connection. I'm guessing the answer is no?
Hi, I have the same issue, did you figure this out and can share with me.
Thanks!
Do you know Brian if a commandlet is in the pipeline for this?
Scratch that, see below
