Hi All,
For every new DataSource, there are few setting I need to change before adding users into it. This setting are like changing working directory, give some minor edit rights etc etc.
The purpose of this task is to avoid humongous repeated work for changing user setting of every user after adding them in DS. I searched in dab module for such cmdlet but no luck.
I think we can change the user setting individually by using the update-PWUsersetting cmdlet but not globally?
Any suggestion would be helpful.
-Aniruddh
I am not seeing a Set-PWUserDefaultSettings cmdlet to go with the corresponding Get-PWUserDefaultSettings cmdlet. If there is enough interest, maybe we can get that added.
Answer Verified By: Aniruddh Chavan
Yes. You are right. First i searched for set-pwuserdefaultsetting cmdlet and ended with update-pwusersetting cmdlet. It would be great help if set cmdlet is made available in dab module.
Aniruddh
We'd like this. I could've sworn it was there honestly.
I thought it was added a while ago. If it was, shouldn't be an issue to add it back.
I think it's one of the few cmdlets that's in PWPS but doesn't have an equivalent in PWPS_DAB.
