Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Creating New Work Area: Template Project not found
    • Sign In
    • State Verified Answer
    • +1 person also asked this people also asked this
    • Replies 2 replies
    • Subscribers 67 subscribers
    • Views 558 views
    • Users 0 members are here
    • powershell
    • projectwise admin
    • pwps_dab
    • ProjectWise PowerShell Modules
    Bhanu Chauhan
    Offline Bhanu Chauhan over 1 year ago
    Recently I switched to a new PC and got PWPS_DAB Version 1.30.13.0 installed. Now when I'm running my New Work Area creation script, it throws a warning like below.
    Security Protocol now set to TLS 1.2
    PWPS_DAB Version is 1.30.13.0
    This is a 64-bit process.
    WARNING: Template project '01 - Civil & Structures (CS)\111-NewTemplate' not found
    WARNING: Creation of new project in temporary folder failed 0
    $data = Get-TablesFromXLSXWorkbook -InputFileName "Complete Path Here\WorkAreaCreation.xlsx"
        foreach($row in $data.Rows)
            $WorkAreaProperties = @{
            PROJECT_ProjectNo = $row.ProjectNo
            PROJECT_ProjectName = $row.ProjectName
            PROJECT_Client_Name = $row.ProjectClientName
            PROJECT_Project_Director = $row.ProjectDirector
            PROJECT_Project_Manager = $row.ProjectManager
        #Using splat for readability.
        $Splat_NewWorkArea = @{
            TemplateName = $row.Template
            StorageArea = $row.StorageArea
            ProjectProperties = $WorkAreaProperties
            DoNotCopyDocuments = $true
        $Splat_NewWorkArea.NewFolderPath = $row.NewWorkAreaPath
        $WorkArea = New-PWRichProject @Splat_NewWorkArea -Verbose
    The Excel file looks like this. It was working fine before.
    Both the ProjectWise Explorer and ProjectWise Administrator CONNECT edition have version 10.00.03.434.
    • Sign in to reply
    • Cancel
    Top Replies
    • Matt Kovach
      Offline Matt Kovach Wed, Jan 19 2022 9:30 AM +1
      Hello Bhanu, Can you confirm that the Template Project Path has not changed in any way? Also, can you check to see if the ProjectWise Template Folder Path (any Folder in the Path) contains " long dashes…
    • Bhanu Chauhan
      Offline Bhanu Chauhan Thu, Jan 20 2022 8:03 AM in reply to Matt Kovach +1 verified
      Oops, that was my bad! I check the script again and it had a line at the top that logs into a different data source. Thanks anyway.
    • Matt Kovach
      0 Offline Matt Kovach Wed, Jan 19 2022 9:30 AM
      Hello Bhanu,
      Can you confirm that the Template Project Path has not changed in any way? Also, can you check to see if the ProjectWise Template Folder Path (any Folder in the Path) contains "long dashes" in the Name? I've experienced issues with Folders containing these special characters, namely when referencing them via Excel, Outlook (Message) or Word. You may want to check to see if the Template Project Path contains "short dashes" while the Excel Spreadsheet may contain "long dashes" (it is difficult to tell by the posted screen capture).
      ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
      ProjectWise Drive, Version 2022.1.328
      OpenRoads Designer CONNECT Edition, Version 10.09.00.91
      OpenRoads Designer CE 202 Release 2, Version 10.10.21.4
      Power GEOPAK V8i (SELECTseries 10), Version 08.11.09.918
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Bhanu Chauhan
      +1 Offline Bhanu Chauhan Thu, Jan 20 2022 8:03 AM in reply to Matt Kovach
      Answer Verified By: Bhanu Chauhan
      • Cancel
      • Sign in to reply
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
