Anyone experiencing similar problems?
After updating to latest PWPS_DAB version 2.0.1.0 I am getting an error running any existing scripts using Select-PWSQL with an output to an Excel spreadsheet.
The SQL results are displayed but the error occurs when attempting to write to Excel
e.g. Select-PWSQL -SQLSelectStatement $SQLstr1 -OutputFile 'c:\temp\file.xlsx'
Error:-
WARNING: Error: Could not load file or assembly 'DocumentFormat.OpenXml, Version=2.7.2.0, Culture=neutral, PublicKeyToken=8fb06cb64d019a17' or one of its dependencies. The system cannot find the file specified. at PWPS_DAB.XLSXDataSetTools.DataSetToXLSXFast(DataSet ds, String sWBName) at PWPS_DAB.SelectPWSQL.ProcessRecord()
In the meantime I will will try rolling back the PWPS_DAB version to see if I can get it working again
Rolled back to 2.0.0.0 and working again
Try version 2.0.2.0 which I just released. I fixed that missing dependency, but, in the meantime, I actually changed the way we generate XLSX files. I think it's an improvement, but happy to hear your feedback.
Answer Verified By: Peter Willmen
Thanks Dave version 2.0.2.0 fixed the dependency issue in Export-PWProjectAccessControl as well.
Possibly unrelated but I've noticed Export-PWAccessControlToExcel is crashing PowerShell in the current versions. I need to rollback a few builds and see when it was last working as we use it a lot.
I've seen this crashing too but think it's related to ProjectWise Office 365 Integration, specifically the latest additional module
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Principal Engineer – Digital
OpenRoads Designer 10.10 | MicroStation CE 10.16 | ProjectWise CE 3.4 | ContextCapture | ProjectWise PowerShell 2.0 | Generative Components | OpenBridge Designer 10.10
Revit 2022 | Civil 3D 2022 | Recap 2022 | Infraworks 2022 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Automate | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Thanks Chris that was on my list to try as well but the day got away from me. I only recently installed the ProjectWise Integration for Microsoft Office 365 v10.00.3907 update so it's a likely candidate for the issue. Will test that tomorrow.
