Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Update-PWWordDocumentFields
    • Sign In
    • State Suggested Answer
    • Replies 3 replies
    • Answers 1 answer
    • Subscribers 65 subscribers
    • Views 491 views
    • Users 0 members are here
    • Title block update
    • MS Excel
    • powershell
    • ProjectWise
    • MS Word
    • Title block integration
    • pwps_dab
    Paul Duffy
    Offline Paul Duffy over 1 year ago
    Just wanted to ask the team, the cmdlet for Update-PWWordDocumentFields, as far as I understand, was set up as a workaround for a specific issue with Title block updates. How easy would it be to adapt this for Excel. And also, is there a way within PowerShell to trigger a Microstation title block update?
    • Sign in to reply
    • Cancel
    • Chris Andrew
      0 Offline Chris Andrew Fri, Apr 29 2022 3:08 AM
      The issue was specific to how word updates fields when not actually being opened.
      Excel and Microstation don't have this issue and the attributes will be updated when you copy out, export, check out or open the file (depending on your settings in PW Admin, with regards to when PW refreshes the attributes).
      Running the checkout cmdlet should do what you need
      Chris
      AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
      Associate Director – Digital
      OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
      Civil 3D 2023 | Dynamo | Navisworks Manage
      PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
      Speckle | BIMVision | Revizto | Solibri
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Paul Duffy
      0 Offline Paul Duffy Tue, May 3 2022 8:48 AM in reply to Chris Andrew
      Thanks for the reply, but that it wasn't I am asking, it is for a specific purpose/use case.
      Paul
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • MWBSI
      0 MWBSI Thu, May 5 2022 5:56 PM in reply to Paul Duffy
      I believe what Chris is saying is that title block update was not completely working for Word, at least at the time, so  the Update-PWWordDocumentFields cmdlet was provided.  Title block update was and is working correctly for Excel and MicroStation, so there is no need for additional cmdlets.   Let us know if that is not the case.
      Going back to your original question, yes PowerShell should be able to perform MicroStation title block updates.  You'll  need to use the Enable-PWTitleblockUpdate cmdlet first on each computer that you want PowerShell to update the title blocks on.  Then you can use the Checkout-PWDocument cmdlet as you see fit to perform the actual title block update.  This cmdlet has export and copyout options.  But you'll need to check out and check the  the document back in to have the update be permanent.  All this should work for Excel files also.
      Hope this helps,
      Mark Weisman | Bentley Systems
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
