Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum update-PWFolderSecurity not found.
    • Sign In
    • State Not Answered
    • Replies 20 replies
    • Subscribers 67 subscribers
    • Views 1786 views
    • Users 0 members are here
    Robert Biggar
    Offline Robert Biggar over 1 year ago
    I am trying to add some security to a folder and I am getting  the below error:
    PS C:\PS> UpdatePWFolderSecurity
    UpdatePWFolderSecurity : The term 'UpdatePWFolderSecurity' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was
    included, verify that the path is correct and try again.
    At line:1 char:1
    + UpdatePWFolderSecurity
    + CategoryInfo : ObjectNotFound: (UpdatePWFolderSecurity:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException
    get-help is finding the cmdlet:
    PS C:\PS> get-help UpdatepwfolderSecurity -full
    Name Category Module Synopsis
    Update-PWFolderSecurity Cmdlet PWPS_DAB UpdatePWFolderSecurity is used to add user(s), group(s), or userlist(s) access control to specified folders.
    Update-PWFolderSecurityByUserL... Cmdlet PWPS_DAB UpdatePWFolderSecurityByUserListSwapWithWorkflow is used to replace existing userlists with another.
    I tried re-importing pwps_dab:
    PS C:\PS> Import-Module pwps_dab
    Security Protocol now set to TLS 1.2
    PWPS_DAB Version is 2.0.6.0
    This is a 32-bit process.
    WARNING: The names of some imported commands from the module 'pwps_dab' include unapproved verbs that might make them less discoverable. To find the commands with unapproved verbs, run the Import-Module command again with the Verbose parameter. For a list of approved verbs, type Get-Verb.
    I even re-installed.
    VERBOSE: Module 'pwps_dab' was installed successfully to path 'C:\Program Files (x86)\WindowsPowerShell\Modules\pwps_dab\2.0.6.0'.
    "Missing something, I am..."
    any ideas?
    all the other cmdlets I call seem to be fine(of course I don't use "ALL", but...)
    Thanks!
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Fri, Apr 8 2022 10:27 PM in reply to Robert Biggar +1
      I see this when copying pasting from Outlook all the time. Also issues with smart quotes. In fact I've seen this so much I wrote a little function that fixes it for me. It converts smart double quotes…
    • Robert Biggar
      0 Offline Robert Biggar Wed, Apr 6 2022 1:25 PM in reply to Brandon Williams
      I think it is "case"...
      <lowercase PWF...>
      PS C:\PS> Update‐pwfolderSecurity
      Update‐pwfolderSecurity : The term 'Update‐pwfolderSecurity' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was
      At line:1 char:1
      + Update‐pwfolderSecurity
      + CategoryInfo : ObjectNotFound: (Update‐pwfolderSecurity:String) [], CommandNotFoundException
      <uppercase PWF...>
      PS C:\PS> Update-PWFolderSecurity
      Update-PWFolderSecurity : Parameter set cannot be resolved using the specified named parameters.
      At line:1 char:1
      + Update-PWFolderSecurity
      + CategoryInfo : InvalidArgument: (:) [Update-PWFolderSecurity], ParameterBindingException
      + FullyQualifiedErrorId : AmbiguousParameterSet,PWPS_DAB.UpdatePWFolderSecurity
      It "finds it" now... I don't recall ever having case issues...maybe I was just lucky and always got the case .."just right"???
      ...thanks for the help! I'm off to the next tree to slam into.."Yoiks and away"
      (assumption on the Looney tune literacy :-D)
      Bob
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Brandon Williams
      0 Offline Brandon Williams Wed, Apr 6 2022 2:17 PM in reply to Robert Biggar
      I copied your first example and the issue seemed to be the -
      When I copied the dash it was shorter then the dash I use. I have no idea how that happened.
      If you copy both cmdlets into powershell you'll see what I mean.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Robert Biggar
      0 Offline Robert Biggar Thu, Apr 7 2022 7:16 AM in reply to Brandon Williams
      yeah, the hyphen definitely needs to be in there...that example without the hyphen was a test someone else observer from the documentation of the cmdlet...a test that didn't work ;-)   It just got caught up in my capture, but thanks, you are absolutely correct. ( I wouldn't want anyone to fall down that rabbit hole).
      It seems the real problem for me was the case of the Text:
      "Update‐pwfolderSecurity" did not work......
      however
      "Update-PWFolderSecurity" does work
      interesting....because
      "New-Pwlogin"  works
      but so does "new-pwlogin"....
      maybe there are some aliases "lurking about"...
      my "takeaway"...sometimes CMDlets ARE case-sensitive...(note to self)
      The way I finally figured it out was to use "intellisense"...I selected from the list and it worked...then compared it to what had been failing.
      I will be using that in the future.
      I appreciate your comments with this....they were a BIG help!
      Bob
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Brandon Williams
      0 Offline Brandon Williams Thu, Apr 7 2022 8:44 AM in reply to Robert Biggar
      So the cmdlet is not case sensitive. The reason it was not working in your examples was because of the dash
      It might not look like much but the first dash is shorter. Almost like it was copied from a file that had a different font, a half dash, which I did not know existed. If you were to copy the above into PowerShell and look at the dash you will see what I mean. The top one is a shorter dash. So even if you copied the top line and did the correct capitals in the cmdlet, it would still not work because of the type of dash. Not sure how to make a half dash but my guess it was copied from a different font?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Robert Biggar
      0 Offline Robert Biggar Thu, Apr 7 2022 8:58 AM in reply to Brandon Williams
      Yep. absolutely correct...  THAT is a good catch.
      ..and a very twisted problem.
      it is the "dash" that is in the "Examples text"...very strange
      I don't have my "Hexedit" handy to check the code on that...but whatever it is...it isn't the dash we need!
      :-D
      Really. nice "Catch" Brandon!
      Thanks!
      Bob
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
