I am looking to rebuild connected projects on connect.bentley.com using Powershell. In the process of attempting to delete my current connected projects from ProjectWise 365 they were instead disconnected from our ProjectWise projects using Remove-PWConnectedProject. I am hoping to delete all of the projects on ProjectWise 365 projects so I can recreate them with working connections using Powershell. It appears there is no tool to do so in bulk on connect.bentley.com. Is there a way to delete all of my projects without manually removing each one? There are >100 projects.
Jack
