Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Unable to Create Project from Template Using PowerShell
    • Sign In
    • State Not Answered
    • Replies 4 replies
    • Subscribers 66 subscribers
    • Views 522 views
    • Users 0 members are here
    • powershell
    Steve Allen
    Offline Steve Allen over 1 year ago
    Good Morning,
    I have been given admin privileges for our  Dev Project in ProjectWise.
    I have tried to create a Project in this test environment within PowerShell using "New-PWRichProjectFromTemplate" and get the attached error message.
    I have been assured I have been granted full admin access to this, is there something else that is missing?
    Please let me know.
    • Sign in to reply
    • Cancel
    Top Replies
    • Sean Duphily
      Offline Sean Duphily Fri, Aug 5 2022 7:53 AM +1
      One thing you can check...someone will need to open the Admin module. Go to your user account properties and check in "Settings Tab -> Work Area -> Can create and upgrade from folders" That must be checked…
    • Sean Duphily
      0 Offline Sean Duphily Fri, Aug 5 2022 7:53 AM
      Go to your user account properties and check in "Settings Tab -> Work Area -> Can create and upgrade from folders"  That must be checked on to be able to create a Work Area (aka RichProject)
      With this setting unchecked, a person as full admin will still not be able to create a Work Area.
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Steve Allen
      0 Offline Steve Allen Tue, Aug 9 2022 7:38 AM in reply to Sean Duphily
      Have tried this but still get the same error from the original post.
      Any other suggestions?
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Sean Duphily
      0 Offline Sean Duphily Tue, Aug 9 2022 11:41 AM in reply to Steve Allen
      The only other way I have been able to get the same error is to force my account trying to create the project as "Read Only" access at the parent folder.  To test if the problem is a permission problem, you can try and get the PW Admin team to adjust your setting for access control and turn it off temporarily (if it's already on).
      With this unchecked, your account will bypass all folder/file permissions and give essentially a "Super User" effect.  It is not a good idea to keep this off for normal user accounts, but for a test, it should help nail down what might be causing the issue.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Matt Kovach
      0 Offline Matt Kovach Tue, Aug 9 2022 1:30 PM
      Hello Steve,
      A few questions:
      1. Are you a member of the Administrator ProjectWise User Group?
      2. Are you able to create a Work Area using ProjectWise Explorer (via the New Work Area Wizard workflow)?
      ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
      ProjectWise Drive, Version 2022.1.328
      OpenRoads Designer CONNECT Edition, Version 10.09.00.91
      OpenRoads Designer CE 202 Release 2, Version 10.10.21.4
      Power GEOPAK V8i (SELECTseries 10), Version 08.11.09.918
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
