Hi all
Echoing what is in the other threat on Copy-PWConnectedProjectSettings I am getting the follow error running it on the latest version of PWPS_DAB and the latest version of the DM connector:
WARNING: Error 'Could not load type 'WSGSharp.RelatedClassAttribute' from assembly 'WSGSharp, Version=2022.2.7.2, Culture=neutral, PublicKeyToken=null'.' retrieving connected project
Trying on a machine with a much older version of the connector the script did run, but I was getting:
WARNING: No rich projects with CONNECTED Projects were passed in.
Even when I was definitely passing in a connected project. I believe this module is the only way to copy DM settings so I really need it to be working!
Thanks in advance
Matt
Surely someone else has this issue?
We have a requirement to updated our connected project settings. I will post my findings in this thread.
