Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Export-PWProjectAccessControl not outputting permissions correctly.
    • Sign In
    • State Not Answered
    • Replies 4 replies
    • Subscribers 64 subscribers
    • Views 467 views
    • Users 0 members are here
    • powershell
    • ProjectWise
    • pwps_dab
    dkleinot
    Offline dkleinot over 1 year ago
    Security Protocol now set to TLS 1.2
    PWPS_DAB Version is 2.1.10.0
    This is a 64-bit process.
    All,
    I ran into an issue with the Export-PWProjectAccessControl cmdlet where it is reporting different permissions then ProjectWise Explorer is:
    VERBOSE: '200_BACKGROUND_DATA' is inheriting access control
    VERBOSE: - Type: 'Document'
    VERBOSE: - MemberName: 't202211901_cei_pm'
    VERBOSE: - AccessMask: '-PCDrwSRWf-'
    VERBOSE: - MemberName: 't202211901_cei_design'
    In the above output you'll see that Powershell is reporting -PCDWrwSRWf- when PW Explorer is showing --CDrwSRWf-. We don't ever give the -PCDrwSRWf- permission.
    Is there something that I'm missing or not understanding here? Or is it an issue with the cmdlet?
    Let me know if there's any additional information you need from me.
    Thanks.
    • Sign in to reply
    • Cancel
    • Brian Flaherty
      0 Offline Brian Flaherty Fri, Aug 19 2022 3:07 PM
      I am not able to replicate your issue. These are the Verbose messages, does the actual returned datatable or exported spreadsheet contain accurate data?
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • dkleinot
      0 Offline dkleinot Mon, Aug 22 2022 1:49 PM in reply to Brian Flaherty
      The returned datatable matches what the Verbose messages are showing.  It was easier to just copy the data from the window.
      I simplified up my code below.  If you need to see the full script let me know:
      $sAccess = Export-PWProjectAccessControl -InputFolder $sfolder.FullPath -FolderLevel 1
          foreach($item in $sAccess){
              $xlPermissions.Cells[$iRow,$iCol].Value = $item.Access_Control_Settings
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • dkleinot
      0 Offline dkleinot Fri, Sep 16 2022 8:37 AM
      FYI, I found another issue.  I am getting folder permissions that shouldn't be happening:
      VERBOSE: '210_PREVIOUS_PLANS' is inheriting access control
      VERBOSE: 	 - InheritingFrom: '01_Active_Projects\DelDOT_Capital_Projects\T201609002'
      VERBOSE: 	 - Type:           'Project'
      VERBOSE: 	 - MemberName:     't201600902_deldot_pm'
      VERBOSE: 	 - AccessMask:     '----r-SRW--'
      As you can see in the above, it's showing  '----r-SRW--' for a folder, which I thought shouldn't even be possible.  It should have read '----r------'.
      I exported to excel directly from PW and it is reporting it correctly.
      I also checked the value directly from the returned datatable and it is showing the same thing:
      if($item.SecurityType -eq "Project"){
      Write-Host (">>AccessControl>>" + $xlPermissions.Cells[1,$iCol].Value + "::" + $item.Access_Control_Settings)
      >>AccessControl>>t201600902_deldot_pm::----r-SRW--
      My next step is to set it programatically and see if it still reads out the same.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Brian Flaherty
      0 Offline Brian Flaherty Fri, Sep 16 2022 3:30 PM in reply to dkleinot
      Yeah, the extraneous folder permissions is a known issue.  Hopefully, it can get fixed.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
