According to the change log, support for $FIELD expression was added in PWPS_DAB version 2.1.18.0
using the following powershell code:
$AuditUser = 'thbn' $SearchField = "`$FIELD(10)`$ = (SELECT DISTINCT o_userno FROM dms_user WHERE o_username in ('$AuditUser'))" $AuditSkabelon = 'Innovationsprojekter\Test_THBN\' $SearchFolder = 'Større anlæg\7x\' Get-PWRichProjects -FolderPath $AuditSkabelon -JustOne | Add-PWSavedSearch -SearchName 'CAD-files' -Environment 'Dokument' -DocumentName $SearchField -SearchFolder $SearchFolder -SearchSubFolders -UpdatedAfter 10/10-2020 -ReplaceExisting -Verbose
Gives the following in the search builder: ='$FIELD(10)$ = (SELECT DISTINCT o_userno FROM dms_user WHERE o_username in ('thbn'))' however, this was the expected search result: $FIELD(10)$ = (SELECT DISTINCT o_userno FROM dms_user WHERE o_username in ('thbn'))
Do we have any examples for writing the $FIELD expression ?
Thank you for bringing this to our attention. Your field syntax is correct. This should work better next release.
Mark Weisman | Bentley Systems
Thanks for the quick response - the code above is now working.However, i am facing issues with FIELD-searches like:
#Search Filtyper $FiltyperArguments = @{ SearchName = 'Filtyper' Description = $userFIELD FileName = "`$FIELD`$ LIKE '%.zip' OR `$FIELD`$ LIKE '%.7z' OR `$FIELD`$ LIKE '%.rar'" SearchFolder = 'Større anlæg\7x\' UpdatedAfter = $AuditDate.AddMonths(-3) SearchSubFolders = $true ReplaceExisting = $true } $AuditProjekt | Add-PWSavedSearch @FiltyperArguments -Verbose Gives the following search value: LIKE '$FIELD$ LIKE '%.zip' OR $FIELD$ LIKE '%.7z' OR $FIELD$ LIKE '%.rar'' And not the expected: $FIELD$ LIKE '%.zip' OR $FIELD$ LIKE '%.7z' OR $FIELD$ LIKE '%.rar'
I dont know if it is related, but i in pwps_dab version 2.1.22.0 i am also getting error running the cmdlet Add-PWSavedFolderSearch. Stating that it can not find 'CreateFolderSearch' in 'PWSearchWrapperX64.dll'
is FIELD-searches also supported in the cmdlet Add-PWSavedFolderSearch ?
Reviewing the change log, it states that we added support for $field$ expression to Add-PWSavedSearch. We will extend that support to other cmdlets as time allows. We will also look into the trailing single quote issue. Fixing Add-PWSavedFolderSearch will be our highest priority.
Add-PWFolderSavedSearch should now be working in the new 2.1.23.0 release. It does not as of yet support $field$ expressions.
Hi
related to Add-PWFolderSavedSearch
i am getting the same date when using the parameters -UpdatedAfter and -UpdatedBefore in the same search.
i am getting "unknown criterion" when using the parameters -ProjectProperties and -ProjectType
