Is there a way to Copy PW Folders with versions through PowerShell?
The GUI has a checkbox to allow this but i cant see a switch in the PowerShell cmdlet
Not in one command. I got it to work by building a list of documents and then using Copy-PWDocumentsToFolder with the -IncludeVersions switch. Downside is the destination folder must exist already for Copy-PWDocumentsToFolder to work. Also I found a bug in the -PopulatePath option for Get-PWDocumentsBySearch.
Anyway, this will backup files from one set of folders to another folder, maintaining the path of the original files and copying the versions.
# Important to NOT use the -GetVersionsToo switch! # -PopulatePath doesn't populate the FolderPath property only the FullPath property # can use -Slow here or use split path on FullPath in loop $pwdList = Get-PWDocumentsBySearch -FolderPath 'Path\To\Source' -PopulatePath # Copy-PWDocumentsToFolder only accepts one target path, and it must exist so we have # to loop through each file to create its directory and calculate the target path ForEach ($pwd in $pwdList) { $fldr = Split-Path $pwd.FullPath -Parent $bkupFldr = Join-Path "Backups" $fldr # Create folder everytime New-PWFolder -FolderPath $bkupFldr > $null $pwd | Copy-PWDocumentsToFolder -TargetFolderPath $bkupFldr -IncludeVersions }
Oh, might be a bit of speed up doing some clever tricks with the folder paths:
$fList = Split-Path $pwdList.FullPath -Parent | Sort -Unique ForEach ($f in $fList) { New-PWFolder -FolderPath (Join-Path 'Backups' $f) > $null }
create the folders first, then remove the New-PWFolder from the document copy loop
We have added a CopyVersions switch to the Copy-PWFolder cmdlet in today's PWPS_DAB release version 23.0.2.0. Note that the Copy-PWFolderBetweenDatasources has always copied versions when they included in the pipeline input.
Mark Weisman | Bentley Systems
Thanks Mark, that would be a massive help! I'm assuming you meant 23.0.2.0, if so i have updated this morning but do not see the new switch?
You also need to use the -IncludeDocuments switch. Try using this switch first, then press the - key and intellisense should present a list of switches. Apparently, there are a lot of them. You have to scroll down towards the bottom. Then you'll see the CopyVersions switch.
Let us know if still have trouble with this.
