Multiple Folders in New-PWScanForReferences -Priority
I am trying to use the New-PWScanForReferences  cmdlet and have it scan multiple Folders to find the references.  The executable wants these separated with a semicolon but this doesn't seem to work.  Per the executable's help, I would also proceed the folder with 'r:' for recursive, but this also does not work and appears to need the -RecursePriority.  It seems a trailing backslash is needed even though the help for the executable does not have this requirement.
From the executable's help:
For example, the combination of:
-masterfolders "Top level folder 3" -masterfolders "Top level folder 1;Top level folder 2"
is equivalent to:
-masterfolders "Top level folder 3;Top level folder 1;Top level folder 2"
My code is:
$myPriority = 'Folder 1\subfolder\;Folder 2\;Folder 3\'
$NewScanRef = @{
DataSourceName = 'myDatasource';
UserName = 'myUserName';
Password = 'mypassword;
ScanMode = 'references;linksets';
MasterDocuments = '{' + $myDocumentGUID + '}';
Priority = $myPriority;
#Proximity = 'r:1';
Order = 'priority;proximity';
#Applications = '';
LogFilePath = $myLogpath ;
New-PWScanForReferences @NewScanRef -RecurseMasterFolders -RecursePriority
I have also tried using
$myPriority = @("Folder 1\subfolder\","Folder 2\","Folder 3\")
And
$myPriority = "Folder 1\subfolder\","Folder 2\","Folder 3\"
With no success.  What am I missing?
  • I managed to get this working with the following:
    $ScanThese = '{GUID1};{GUID2};{GUID3}'
    $myPriority = 'Folder 1\subfolder;r:Folder 2;r:Folder 3'
    $NewScanRef = @{
    MasterDocuments = $ScanThese;
    Priority = $myPriority ;
    LogFilePath = $logpath ;
    New-PWScanForReferences @NewScanRef -RecursePriority
    Replace GUID1 with the actual GUID, retaining the {} around the GUID.  Do the same for GUID 2 and GUID 3
    Apparently adding the r: to the first folder in the Priority causes a problem.  The -RecursePriority is applied to the first folder in the list, but not the subsequent ones.  I therefore added the r: in front of the subsequent folders for a recursive search in them.  I did not expect this inconsistency, but I believe there are a few things inconsistent with the cmdlet and the executable since I could set the Proximity to r:2 when running the executable from the command line but not via the cmdlet.
