Cmdlet Request: Fast tests for folder/file/user existance
Frequently I want to verify a document, folder or user exists before I do something so that if it doesn't exist I can give a decent message in the log or to the user (me). But using the various Get- functions to retrieve the object and do something if that fails seems slow if I don't need all the info?
Would it be possible to get test cmdlet that return much quicker if the object does or doesn't exist?
Test-PWDocument
    -InputFolder
    -FolderPath
    -FolderID
    -InRoot
    -DocumentName (accepts wildcard)
    -FileName (accepts wildcard)
Test-PWFolder
    -InputFolder
    -FolderPath
    -FolderID
    -InRoot
    -FolderName (accepts wildcard)
Test-PWUser
    -UserName
    -UserID
    -Email
    -Identity
Where FolderPath/FolderID/InputFolder/InRoot is the parent directory to search in. I would not recurse the search into subfolders.
  • Hey Kevin,
    Here is a function that I use which is similar to what you are trying to do. It only works with documents and folders, but may be useful.
    .Synopsis
       Test if folder or document exists.
    .DESCRIPTION
       Used to determine if a folder or document exists.
    .EXAMPLE
       Returns the document guid and name of any documents found. Uses wildcards.
        $Splat_Test = @{
          Type = 'Document'
          FolderID = 179
          Name = 'a111-view'
          FileName = '1.dwg'
        $resultsDocuments = Find-PWIfExists @Splat_Test -UseWildCards -Verbose
    .EXAMPLE
       Returns the folder guid and name of any folders found. Uses wildcards.
        $Splat_Test = @{
          Type = 'Folder'
          Name = 'CAD_Data'
        $resultsFolders = Find-PWIfExists @Splat_Test -UseWildCards -Verbose
    .OUTPUTS
       Returns a list of datarows containing the object guid and name.
    FUNCTION Find-PWIfExists{
        [CmdletBinding()]
        [OutputType([string])]
        Param (
            # Type of object to test for.
            [Parameter(Mandatory=$true)]
            [ValidateNotNullOrEmpty()]
            [ValidateSet('Document', 'Folder')]
            [string] $Type,
            # Folder ID of object to test for (Document or Folder).
            [Parameter()]
            [int] $FolderID,
            # Name of object to test for.
            [Parameter()]
            [string] $Name,
            [Parameter(ParameterSetName='Doc')]
            [string] $FileName,
            [switch] $UseWildCards
        ) # end Param...
        BEGIN {
          $CmdletName = $MyInvocation.MyCommand.Name
          $StartTime = Get-Date
          Write-Host -Message "[BEGIN] $StartTime - Entering '$CmdletName' Function..." -ForegroundColor Green
        } # end BEGIN...
        PROCESS{
          #region TEST FOR FOLDER
          if($Type.ToLower().Equals('folder')){
            try {
              if([string]::IsNullOrEmpty($Name)){
                throw "Folder Name must be included."
              $Where = "WHERE o_projectname LIKE '%$NAME%'"
              if( -not ($UseWildCards)){
                $Where = $Where.Replace('%', [string]::Empty)
              $SQLSelectStatement = "SELECT o_projguid AS ProjectGUID, o_projectname AS Name FROM dms_proj $Where"
              Write-Host "SQL query '$SQLSelectStatement'" -ForegroundColor Green
              $results = Select-PWSQL -SQLSelectStatement $SQLSelectStatement -ErrorAction Stop
              Write-Host "$($results.Rows.Count) documents returned." -ForegroundColor Green
            } catch {
              Write-Warning -Message $Error[0].Exception.Message
          #endregion TEST FOR FOLDER
          #region TEST FOR DOCUMENT
          if($Type.ToLower().Equals('document')){
            try{
              if([string]::IsNullOrEmpty($Name) -and [string]::IsNullOrEmpty($FileName)){
                throw "Either Name or FileName must be included."
              $Where = [string]::Empty
              if( -not ([string]::IsNullOrEmpty($FolderID))){
                $Where = "WHERE o_projectno = $FolderID"
              if( -not ([string]::IsNullOrEmpty($Name))){
                if($Where.Contains('WHERE')){
                  $Where = "$Where AND o_itemname LIKE '%$Name%'"
                } else {
                  $Where = "WHERE o_itemname LIKE '%$Name%'"
              if( -not ([string]::IsNullOrEmpty($FileName))){
                  $Where = "$Where AND o_filename LIKE '%$FileName%'"
                } else {
                  $Where = "WHERE o_filename LIKE '%$FileName%'"
              if( -not ([string]::IsNullOrEmpty($Where))){
                $SQLSelectStatement = "SELECT o_docguid AS DocGUID, o_itemname AS NAME, o_filename AS FileName FROM dms_doc $Where"
            } catch {
          #endregion TEST FOR DOCUMENT
          if( -not ([string]::IsNullOrEmpty($results))){
            Write-Output $results
          } else {
            Write-Host "No documents found." -ForegroundColor Cyan
        } # end PROCESS...
      END {
        $EndTime = Get-Date
        Write-Verbose -Message "[END] It took $($EndTime - $StartTime) to complete the process." -Verbose
        Write-Verbose -Message "[END] $EndTime - Exiting '$CmdletName' Function..." -Verbose
      } # end END...
    } # end FUNCTION Find-PWIfExists...
    Export-ModuleMember -Function Find-PWIfExists
