Not sure if anyone else will find this useful but I got tired of writing functions that had different parameters for different ways of pointing at a projectwise document. so here's an example of a function that accepts one parameter -Document and parses the parameter to get it to a projectwise document object.
If a projectwise document object is passed in it just sends it through (if you wanted to you could have it re-fetch the document and add -populatepath or -slow)
If a string is passed it the string is evaluated and will fetch a projectwise document if it's a URL, URN, GUID, or Folder Path + Filename.
Function Example-Function { <# .SYNOPSIS Takes something that points at a ProjectWise Document and returns a ProjectWise Document object .DESCRIPTION Accepts a string or ProjectWise Document object from pwps_dab and returns a pwps_dab ProjectWise Document object. Strings can be a path to the file (including the filename), a ProjectWise URL or URN or just a GUID string. .PARAMETER Document Path to ProjectWise document. Can be a ProjectWise document object or a ProjectWise URL or a GUID or just a path. .EXAMPLE $path = 'Path\to\Projectwise\Filename.ext' $pwdoc = Example-Function -Document $path .EXAMPLE $url = 'pw://intsrv:dsource/Documents/Path/to/ProjectWise/Filename.ext' $pwdoc = Example-Function -Document $url .EXAMPLE $guid = '{e2e88a23-a959-4d09-ad29-bab7bf5275dc}' $pwdoc = Example-Function -Document $guid .EXAMPLE $urn = 'pw://intsrv:dsource/Documents/D{e2e88a23-a959-4d09-ad29-bab7bf5275dc}' $pwdoc = Example-Function -Document $urn #> [CmdletBinding()] Param ( [Parameter( Mandatory, ValueFromPipeline, ValueFromPipelineByPropertyName, HelpMessage = 'ProjectWise document. Can be a path, guid, URL or ProjectWise document object.' )] [ValidateNotNullorEmpty()] [Object]$Document ) $pwd = $null $docType = $Document.GetType() if ($docType -eq [PWPS_DAB.CommonTypes+ProjectWiseDocument]) { $pwd = $Document } elseif ($docType -eq [String]) { if ($document -like "pw:*") { # this extracts everything after the /Documents/ part of the URL # then lets the normal string handling deal with it $document = ($document.split('/\',5))[4] } $warnResult = $null if (($document -like "{*}") -or ($document -like "D{*}")) { $document = $document.TrimStart("D") $pwd = Get-PWDocumentsByGUIDs -DocumentGUIDs $document -wa SilentlyContinue -wv WarnResult if (-not [string]::IsNullOrEmpty($warnResult)) { Throw $WarnResult } } else { # assume all other strings are a folder path with filename at the end $path = Split-Path $document -parent $file = Split-Path $document -leaf try { $pwd = Get-PWDocumentsBySearch -FolderPath $path -FileName $file -JustThisFolder -PopulatePath -wa SilentlyContinue -wv warnResult } catch { $pwd = $null $warnResult = "Error occurred retrieving document with GUID $($document). GUID may be invalid." } if (-not [string]::IsNullOrEmpty($warnResult)) { Throw $WarnResult } } } else { Throw "Invalid object type passed. Document parameter must be a ProjectWise document or a string object." } return $pwd }
It assumes you're already logged into the correct projectwise datasource so for a url/urn it won't login in first, just extracts the path and then gets the document object.
I like it!
