Set-PWFolderWorkflow or Set-PWWorkflowByFolderPath Throwing error and not attaching workflow
I'm trying to attach a workflow to a folder.
I can attach it manually from the  settings dialog ( so I think the Folder and the Workflow are working)
when I try to use "Set-PWFolderWorkflow" (or "Set-PWWorkflowByFolderPath")
the CMDlet is erroring out:
WARNING: Failed to set the workflow for folder 'MiFiles'. ErrorID: 56046
WARNING: Failed to set workflow for 'MiFiles'.
56046 -  "Could not find the specified table in the database"
the code I am using goes like this:
$TargetPath = "Lansing Support\biggarr\MiFiles"
$NewWorkflow = "Act51 - Submittals"
write-Host "Reading Target Folder..."
if ($PWfolder = Get-PWFolders -FolderPath $TargetPath -JustOne)
      Set-PWFolderWorkflow -InputFolder $PWfolder -NewWorkflow 'Act51 - Submittals' -Verbose
else
      write-Host "Target Folder NOT found..."
Not a lot of detail to these CMDlets....
Can anyone see anything I may be off track on?
Thank You, I appreciate it.
Bob
