Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum New-PWRenditionRequest add the possibility to choose the Profile-Settings like File-Presentation and so on
    • Sign In
    • State Not Answered
    • Replies 5 replies
    • Subscribers 65 subscribers
    • Views 186 views
    • Users 0 members are here
    • ProjectWise
    • pwps_dab
    • powershell_dab
    Niels Wehr
    Offline Niels Wehr 4 months ago
    Atm its not possible to create an rendition with this request whit an pre defined File-Presentation which is already part of this profile.
    Only the default one can be used.
    • Sign in to reply
    • Cancel
    • MWBSI
      0 MWBSI Thu, May 18 2023 8:56 AM
      Please see new parameters added to this cmdlet for the latest release of PWPS_DAB.
      Mark Weisman | Bentley Systems
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Niels Wehr
      0 Offline Niels Wehr Mon, May 22 2023 1:42 AM in reply to MWBSI
      Hello! Thx for the fast implementation. I can report that it works untill i define the default value as the optional setting, than there is an error. This should be an easy fix I think.
      For now I can live with that as i know what i set as default values and no one else is changing them.
      But there ist no way that an other one would know what i did define as the default until he cheks it with the administrator. Maby an addidtional cmdlet to fetch the assinged RenditionProfile settings and the default values? Or maby a switch to get this informations within Get-PWRenditionProfiles?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • MWBSI
      0 MWBSI Mon, May 22 2023 9:34 PM in reply to Niels Wehr
      I'm not seeing this.  Please reply with the command line you are using.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Niels Wehr
      0 Offline Niels Wehr Tue, May 23 2023 1:10 AM in reply to MWBSI
      I'am using this (all these options are avaliable within the create renditions dialog in PW for that RenditionProfile):
      New-PWRenditionRequest -InputDocuments $PWDocuments -DestinationOption 'PDF_Update' -FilenameOption 'DokumentenName' -MakeSinglePlotRequest -PresentationOption 'WFL-A2-PDF' -ProfileName 'PDF_Rendition' -RenditionOption 'PDF'
      The values which are identical with the defaults would be -FilenameOption 'DokumentenName' and -RenditionOption 'PDF'.
      Untill I remove all settings values which are equal to the defaults Im getting the folowing error:
      WARNING: Error submitting plot request. Untill i remove all settings which are default.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • MWBSI
      0 MWBSI Wed, Jun 7 2023 5:04 PM in reply to Niels Wehr
      This should work better now with the latest version of PWPS_DAB.  Let us know if this is not the case.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
