Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Performance monitor - Merge SQLite databases if running from separate regions - Just Sharing
    • Sign In
    • State Not Answered
    • Replies 1 reply
    • Subscribers 66 subscribers
    • Views 229 views
    • Users 0 members are here
    • powershell
    • Performance
    • ProjectWise
    • SQL
    Chris Spencer
    Offline Chris Spencer 3 months ago
    Maybe someone has a PowerShell script to do the same thing or a neater way? (Merging multiple sqlite databases to one - Machines were from different regions with no access to a central db) For this I required sqlite3.exe from the sqlite tools bundle and piped the SQL
    --Bentley Performance database merge to one for sqlite databases.
    --Usage from command line: sqlite3.exe global.sqlite < MergeSQL.sql
    --Where this file is MergeSQL.sql and global.sqlite is a copy of any db designated as master global
    --Empty tables
    delete from PWPerfEnvironment;
    delete from PWPerfFolder;
    delete from PWPerfGeneral;
    delete from PWPerfUser;
    delete from PWPerfDocument;
    --Merge in database 1
    attach 'C:\path-to-db1\PW_Perf_db1.sqlite' as toMerge;
    BEGIN;
    insert into PWPerfDocument select * from toMerge.PWPerfDocument;
    insert into PWPerfEnvironment select * from toMerge.PWPerfEnvironment;
    insert into PWPerfFolder select * from toMerge.PWPerfFolder;
    insert into PWPerfGeneral select * from toMerge.PWPerfGeneral;
    insert into PWPerfUser select * from toMerge.PWPerfUser;
    COMMIT;
    detach toMerge;
    --Merge in database 2 and so on....
    attach 'C:\path-to-db2\PW_Perf_db2.sqlite' as toMerge;
    BEGIN;
    COMMIT;
    detach toMerge;
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Wed, Jun 28 2023 10:28 AM +1
      I use the SimplySQL powershell module to work with SQLite from powershell but I've never tried to do any table merges from 2 different datasources with it. GitHub - mithrandyr/SimplySql: PowerShell module…
    • Kevin van Haaren
      0 Offline Kevin van Haaren Wed, Jun 28 2023 10:28 AM
      GitHub - mithrandyr/SimplySql: PowerShell module for querying various SQL databases
      The Invoke-SQLBulkCopy might make it easier:
      NAME
          Invoke-SqlBulkCopy
      SYNOPSIS
          Executes a bulk copy between two connections.
      SYNTAX
          Invoke-SqlBulkCopy [-SourceConnectionName <String>] [-DestinationConnectionName <String>] -SourceTable <String>
          [-DestinationTable <String>] [-ColumnMap <Hashtable>] [-BatchSize <Int32>] [-BatchTimeout <Int32>] [-Notify] [-NotifyAction
          <ScriptBlock>] [<CommonParameters>]
          Invoke-SqlBulkCopy [-SourceConnectionName <String>] [-DestinationConnectionName <String>] -SourceQuery <String[]>
          [-SourceParameters <Hashtable>] -DestinationTable <String> [-ColumnMap <Hashtable>] [-BatchSize <Int32>] [-BatchTimeout <Int32>]
          [-Notify] [-NotifyAction <ScriptBlock>] [<CommonParameters>]
      DESCRIPTION
          Executes a bulk copy operation between two connections.  This is highly
          optimized if the destination has a managed bulkcopy implemenation, otherwise
          it is only generally optimized.  For example, SQL Server has a bulk copy
          class (SqlBulkCopy) that is easily implemented and provides an efficient
          means of inserting data into SQL Server.
          The default implemenation, if the provider does not provider a managed
          bulk copy mechanism is to prepare the sql insert, and wrap multiple inserts
          into a single transaction (batching).  This provides a significant
          performance improvement over looping with Invoke-SqlUpdate.
          CONSIDERATIONS
          * You must specify either a SourceConnectionName or DestinationConnectionName,
              whichever one is not specified will use 'default', not specifying either
              will cause an error.
          * If you donâ?Tt specify DestinationTable, it will use SourceTable; however
              DestinationTable is required if you use SourceQuery.
          * If you specify ColumnMap and Source Table, then the select against the
              SourceConnection will be limited to the columns you specified in ColumnMap.
          Returns number of rows copied.
      PARAMETERS
              User defined name for connection where data will be queried from.
              User defined name for connection where data will be inserted to.
              The name of the table in the source connection.
              The query to determine the source data, instead of specifying a table.
              Parameters needed for the source query.
              The name of the table to write to in the destination connection.
              If not specified, will be taken from SourceTable parameter.
              Key is the column name in the source connection.
              Value is the column name in the destination connection.
          -BatchSize <Int32>
              How many inserts are batched together at one time.
              How long, in seconds, that each batch can take.
              Defaults to the command timeout for the source connection.
          -Notify [<SwitchParameter>]
              If present, as each batch completes a progress notification will be
              generated with the total number of rows inserted so far.
              If specified, then on the completion of each batch, this action will be invoked.
              The first argument will have the rows completed so far, either use $args[0]
              or specify a param block.
          <CommonParameters>
              This cmdlet supports the common parameters: Verbose, Debug,
              ErrorAction, ErrorVariable, WarningAction, WarningVariable,
              OutBuffer, PipelineVariable, and OutVariable. For more information, see
              about_CommonParameters (https:/go.microsoft.com/fwlink/?LinkID=113216).
      REMARKS
          To see the examples, type: "get-help Invoke-SqlBulkCopy -examples".
          For more information, type: "get-help Invoke-SqlBulkCopy -detailed".
          For technical information, type: "get-help Invoke-SqlBulkCopy -full".
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Kevin van Haaren
      NAME
          Invoke-SqlBulkCopy
      SYNOPSIS
      SYNTAX
      DESCRIPTION
          CONSIDERATIONS
      PARAMETERS
          -BatchSize <Int32>
          <CommonParameters>
      REMARKS
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
