Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Publishing Forum Plotting AutoCAD Drawings That Include Wipeouts
    • Sign In
    • State Not Answered
    • Replies 4 replies
    • Subscribers 8 subscribers
    • Views 4393 views
    • Users 0 members are here
    • linestyle
    • ProjectWise InterPlot Organizer
    • Iplot Organizer
    • Interplot CTB files
    • DWG
    • InterPlot Organizer
    jgarza
    jgarza over 8 years ago
    I am trying to plot AutoCAD drawings from within ProjectWise that include wipesouts (Text Masking) but when the pdf files are created all I get is a solid black square around the text. I also noticed that the in AutoCAD you have the option for linetype scaling if you are printing from Paperspace. I see no such option in Interplot settings. So my plotting line weights are a little darker frm what they should be.
    • Sign in to reply
    • Cancel
    • Todd Combs
      0 Offline Todd Combs Thu, May 14 2015 10:03 AM
      Both issues may be related to a design script resymbolizing the plot. Test without a design script to see if it is causing the problem. If it is, add the following to the design script:
      if (type == text) then
      fill_color = (255,255,255)
      boundary_color = (255,255,255)
      color = (0,0,0)
      endif
      This should print the background and boundary white and print the characters black.
      The cls_scale design script keyword scales the custom line style.
      This example will scale all linestyles by 1/2:
      if (cls_name .ne. 'none') then
      cls_scale = 0.5
      endif
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • MichaelGilham
      0 Offline MichaelGilham Tue, Jan 24 2017 10:50 PM in reply to Todd Combs
      Hi Todd,
      I'm struggling to get an AutoCAD "wipeout" to plot as expected using a design script and ICS/InterPlot.
      The interior area of the wipeout is fine - it seems to appear in MicroStation as the background colour so, when I create the PDF, it is white - perfect.
      But the shape around the outside of the wipeout shows in MicroStation and, using element information, the colour is shown as "DWG Special Colors:DWG Color 255 (210,210,210)". And this plots as black in the PDF.
      I did find another thread that provides a MicroStation configuration variable that can assign this DWG special color to a RGB value. After some experimentation with the RGB value, I did manage to create a PDF that did not have the wipeout area shown (much to my amazement). I have a concern that implementing this configuration valuable on an ICS server might break something else... so here's my question.
      Is there a method that can be implemented within the desgn script that can find any/all "wipeouts" and ensure they do show up in the PDF?
      Michael
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Todd Combs
      0 Offline Todd Combs Wed, Jan 25 2017 8:28 AM in reply to MichaelGilham
      Michael,
      If testing off color is not option, you will need to test off type or level name or reference file, etc…., or with a combination, and then assign boundary_color = (255,255,255). Refer to the PW InterPlot Help for a list of Design Script comparison keywords and examples.
      Todd
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • MichaelGilham
      0 Offline MichaelGilham Sun, Jan 29 2017 10:47 PM in reply to Todd Combs
      Thanks Todd.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • MichaelGilham
      Thanks Todd.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
