Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Publishing Forum Untitled Viewport Created By Interplot
    • Sign In
    • State Suggested Answer
    • Replies 6 replies
    • Answers 1 answer
    • Subscribers 8 subscribers
    • Views 3196 views
    • Users 0 members are here
    Matthew Peneguy
    Offline Matthew Peneguy over 8 years ago
    When I create a pdf from Interplot it creates two "Untitled" viewports.  These viewports have nothing to do with the scale of the drawing, and thus should not be there.  Where is the setting in Interplot to disable these unwanted viewports?
    • Sign in to reply
    • Cancel
    • Todd Combs
      0 Offline Todd Combs Thu, Jun 4 2015 9:08 AM
      Matthew,
      Perform a test with "Disable Saved Views" enabled in the PDF Format Configuration dialog.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Matthew Peneguy
      0 Offline Matthew Peneguy Thu, Jun 4 2015 9:24 AM in reply to Todd Combs
      Thanks for the quick reply.
      I tried that and still have the same result.
      I gleaned a little more information, the scales on the viewports are 1":8.73504" and 1":11.6467".
      One other thing... I don't know how other people have setup Interplot, but in our setup Interplot searches for a "border shape" in the dgn to create the plot region. Could this be part of the problem?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Todd Combs
      0 Offline Todd Combs Thu, Jun 4 2015 9:51 AM in reply to Matthew Peneguy
      A multiple page PDF can be created if the settings file has “Create one plot from each matching shape” enabled, and the file contains multiple shapes that match your plot shape. Is each viewport in the viewer a separate page? How does Adobe Reader display this file? Upload the PDF and \ or design file and settings file if necessary.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Matthew Peneguy
      0 Offline Matthew Peneguy Thu, Jun 4 2015 11:51 AM in reply to Todd Combs
      Todd,
      Thanks for following up on this.
      Using our full scale printer settings file to generate pdfs required us to manually crop a 48x36 pdf to create a correctly sized 22x34 pdf... ( See BorderShape files in the attachment) The two Untitled viewports in that pdf are scaled at 1:12.  Viewports are supposed to only be used to display special scales.  So, this is incorrect.
      Because manually cropping these files was wasting a lot of our group and section's time, I went ahead and made a modified settings file that generates a 22x34 pdf, and that's where I'm getting the differently scaled Untitled viewports. (See the 22x34 files in the attachment)Interplot Problems.zip.
      Regardless of scale, we shouldn't be including any viewports in any of our pdfs, we do not use that type of functionality in our drawings.  And even if we wanted to, our configuration with Interplot isn't set up to support it.
      When I open the files in Adobe I don't know where to find viewport information...   Though, the scaling is correct in both Revu and Acrobat.
      Please help us find where these Untitled viewports are coming from.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Matthew Peneguy
      0 Offline Matthew Peneguy Thu, Jun 4 2015 3:55 PM in reply to Matthew Peneguy
      Thank you Todd!
      He has solved the problem!
      The short term solution is to add:
      IPLOTSRV_NO_PDF_MEASURE = true
      to the iplotsrv.cfg file.
      The long term solution may be up for debate... We don't use the Model space/Sheet space in Microstation. So, I really don't have a handle on where Microstation is in regard to Model/Sheet space and whether they want to utilize multiple correctly scaled viewports in the produced pdfs.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
