Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Publishing Forum ProjectWise InterPlot Organizer and ProjectWise InterPlot Server CONNECT Edition refresh released
    • Sign In
    • State Not Answered
    • +1 person also asked this people also asked this
    • Replies 4 replies
    • Subscribers 10 subscribers
    • Views 7318 views
    • Users 0 members are here
    • InterPlot Server
    • InterPlot Organizer
    Jo Terri Wright
    Offline Jo Terri Wright over 6 years ago
    A refresh of ProjectWise InterPlot Organizer and ProjectWise InterPlot Server CONNECT Edition (10.00.00.64) is available from the Software Downloads site.
    This release includes a few updates in the following areas::
    • Usage of an IMS account with Organizer and ProjectWise Explorer
    • Managed Workspaces
    • Clip boundaries when using MicroStation CE print engine
    Information from the initial ProjectWise InterPlot CONNECT Edition release:
    • CONNECT Edition Support – ProjectWise InterPlot Organizer is now compatible with CONNECT Edition releases of ProjectWise, MicroStation, PowerDraft and other MicroStation-based applications.
    • Support for PDF/A-1b Standard – PDF/A-1b is now supported in ProjectWise InterPlot Organizer when exporting to PDF, and also in digital archiving when creating PDF as an additional format.
    • Microsoft Office Support – ProjectWise InterPlot Organizer is now compatible with Office 2010, 2013, 2016, and 365, including 32-bit and 64-bit versions.
    • Processing Engine Requirement– InterPlot Organizer requires MicroStation, PowerDraft, Bentley View, or a compatible MicroStation-based application to act as a processing engine for the plotting of DGN and DWG files. This release no longer bundles Bentley View in the InterPlot Organizer setup files. However, if you do not already have a compatible processing application installed, download the free Bentley View application or a MicroStation-based application from Bentley's Software Downloads site.
    • ProjectWise InterPlot Organizer CONNECT Edition is supported on Windows 7 (32 and 64-bit), Windows 8.1 (64-bit), Windows 10 (64-bit), Windows Server 2008 R2 (64-bit) and Windows Server 2012 R2 (64–bit). ProjectWise InterPlot Server CONNECT Edition is supported on Windows Server 2008 R2 (64-bit) and Windows Server 2012 R2 (64–bit).
    ProjectWise InterPlot CONNECT Edition supports plotting from MicroStation J, V8 2004, V8 XM Edition, V8i, V8i (SELECTseries 1 -4) and CONNECT Edition. When plotting to ProjectWise InterPlot Server CONNECT Edition, a hard copy or electronic deliverable such as PDF and TIFF is created from a variety of formats, including DGN, DWG, industry standard raster, DPR, PDF and Microsoft Office files. PDF files can be created locally from ProjectWise InterPlot Organizer in a standalone mode.
    ProjectWise InterPlot Organizer CONNECT Edition is enabled by a Bentley CONNECTIONS Passport License.
    Note: ProjectWise InterPlot Server CONNECT Edition (10.0.0.64) is only compatible with ProjectWise InterPlot driver products version 10.0.0.XX and later. Prior driver product versions are not compatible and can cause an error during plotting.
    • Sign in to reply
    • Cancel
    • Daren Long
      0 Offline Daren Long Tue, Sep 5 2017 2:33 PM
      Where can I find the ProjectWise InterPlot Server CONNECT Edition Readme file?
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dawn Clark Gentry
      0 Offline Dawn Clark Gentry Tue, Sep 5 2017 2:49 PM in reply to Daren Long
      Once the product is installed, it will be located in C:\Program Files (x86)\ProjectWise InterPlot Server.  I have placed it here for your convenience.
      https://bentley.sharefile.com/d-sccc55b3b36d49f4a
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Daren Long
      0 Offline Daren Long Tue, Sep 5 2017 2:54 PM
      Thank You!
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Neil Norberg
      0 Offline Neil Norberg Thu, Mar 1 2018 12:56 PM
      Is there an ETA on when Windows Server 2016 compatible version will be made available?
      • Cancel
      • Vote Up -1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
