Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Publishing Forum i-model Composition Server for i-models CONNECT Edition 10.00.02.59 now available on Software Downloads
    • Sign In
    • Replies 0 replies
    • Subscribers 7 subscribers
    • Views 2122 views
    • Users 0 members are here
    Jo Terri Wright
    Offline Jo Terri Wright over 6 years ago
    The i-model Composition Server team is pleased to announce that a refresh of i-model Composition Service for i-models, Bentley Automation Service CONNECT Edition 10.00.02.59, is available from Software Downloads. Please refer to the "What's New" section below for a list of updates in this 10.00.02.59 release as well as the previous 10.00.02.20 release.
    What is i-model Composition Service for i-models?
    The i-model Composition Service for i-models automates the production of published, packaged and mobile i-models from design files stored in ProjectWise, based on pre-established workflow rules, eliminating manual processing. With the integration of i-model Transformer, this service enables transformations to create fit-for-purpose i-models.
    Features of i-model Composition Server for i-models:
    • Produce intelligent deliverables in the form of Published, Packaged and mobile i-models
    • Automate i-model creation from DGN, DWG, Civil 3D and IFC files managed in ProjectWise
    • Automate jobs based on predefined settings and operational rules for format, filename and destination on a predefined schedule including specified files, folder contents or saved searches
    • Create deliverables automatically as originating files are updated in ProjectWise
    What’s New in i-model Composition Server for i-models 10.00.02.59 (Refresh release):
    • Support for MicroStation CONNECT Edition Update 5
    • Support for ProjectWise CONNECT Edition Update 2.2
    • Full Managed Workspace support
    • AECOsim Building Designer CONNECT Edition support
    What’s New in i-model Composition Server for i-models 10.00.02.20:
    • Process management improvements
    • More details in the Job Monitor job status
    • Creates i-models from AutoCAD Civil 3D files
      Creates DgnDb 0601 format mobile i-models
      • Important note: If users are running an older version of Bentley Automation Service and are not yet running the latest applications that read the new mobile i-model format, please do not have them upgrade to Bentley Automation Service CONNECT Edition until they transition to the new Navigator and mobile apps as BAS only produces the new format i-models.
      • Bentley Navigator CONNECT Edition Update 3 or Navigator Mobile Update 3 are the minimum versions required to view .imodel files created from Bentley Automation Service CONNECT Edition.
    • Integration with i-model Transformer 9.0.1.7
      • Older versions of iMT are no longer supported and BAS no longer delivers or requires the iMT install set.
      • Users can download iMT from Software Downloads. Bentley i-model Transformer x86 Components 9.0.1.7 must also be installed and the installer is delivered in ...\Bentley\imodelTransformer\x86Components\.
    • Use any MicroStation-based application as the DGN Indexing processing engine
    Bentley i-model Composition Server for i-models - Requires an i-model publishing engine of your choice (see the Readme on docs.bentley.com) and i-model Transformer if i-model transformation and validation is needed. With a SELECT contract, Bentley i-model Composition Server is enabled with an iCS V8i license or for a CSS it is part of the ProjectWise Design Integration Server Suite.
    DGN Indexing - This extension of Bentley Automation Service is used to create an index in the datasource of component-level information extracted from standard 2D and 3D DGN or DWG documents. This component-level information includes cells, levels, linestyles, etc. The DGN Indexing extension does not require a separate license.
    For more details on Bentley Automation Service CONNECT Edition, please see the Readme on docs.bentley.com.
    Currently, on the Software Downloads site, you will need to remove the "CONNECT Edition" filter in order to find Bentley Automation Service CONNECT Edition. We are working to clear up this issue.
    • Sign in to reply
    • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
