In ProjectWise explorer we have an option to create SET files by right clicking in the document area-> Right Click-> Set -> New
how do we create these SET files in ProjectWise web server? There does not seem to be an option in web server.
That is true. Please be aware that ProjectWise web server has been deprecated.
so it means there is no way of creating SET file in web server? Also, is web server being discontinued in Connect series?
Correct. Yes, there is no ProjectWise Web Server in the CONNECT Edition. ProjectWise Web View Server is no longer delivered and has been discontinued.
Thanks Ed but I thought ProjectWise web server was still in use in Connect series but ProjectWise Web View server was discontinued.
Hi Rakhi Bhargava,
I am not sure if you had received any further input on your question, but ProjectWise Web Server has been superceded by Bentley Web Services Gateway where some additional information about this can be found in the Bentley Web Services Gateway FAQs and you can open a Service Request to request a Product Enhancement (for functionality desired/needed) on connect.bentley.com.
HTH,Bob
I would like to know if it is possible to create sets in the web client and what is the procedure to carry out this process.
I would also like to know if it is possible to copy a set from one dataset to another in an automated way.
Thanks.
