Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Publishing Forum Projectwise Interplot Server installation error
    • Sign In
    • State Not Answered
    • Replies 4 replies
    • Subscribers 7 subscribers
    • Views 1398 views
    • Users 0 members are here
    lilsweepr
    Offline lilsweepr over 3 years ago
    PWIS version - 10.00.02.29 (SES)
    Server OS version - Windows Server 2016 Standard 1607
    Getting an error when installing the server software - "There was a problem with the ProjectWise InterPlot Organizer installation. Status:2"
    Has anyone else tried installing this version and run into this?
    Robert
    • Sign in to reply
    • Cancel
    • Todd Combs
      0 Offline Todd Combs Wed, Jun 17 2020 12:14 PM
      Hi Robert,
      It appears you are attempting a silent install? If so, the folder structure will need to be staged prior to executing setup.exe.
      Open a Command Window “As Administrator”
      Extract the single file installer to a temporary folder:
      pwpsv10000229en.exe /Q /C /T:c:\temp
      cd c:\temp
      stageiporg.cmd
      setup.exe -s
      To activate the product after installation:
      cd C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService
      Bentley.Licensing.ActivationWizard.exe /serversetup
      For activation assistance:
      https://communities.bentley.com/products/projectwise/content_publishing/w/wiki/48707/projectwise-interplot-server-products-registration-and-ses-activation
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • lilsweepr
      0 Offline lilsweepr Wed, Jun 17 2020 12:17 PM in reply to Todd Combs
      Actually, no. Just initiated the install from the setup.exe file. I did use 7-zip to unzip the downloaded file to the pwpsv10000229en folder first. Could this have been the problem?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Todd Combs
      0 Offline Todd Combs Wed, Jun 17 2020 12:38 PM in reply to lilsweepr
      Perhaps, try executing stageiporg.cmd to stage the folders and then setup.exe. If it continues to give you trouble, use the instructions I provided without the -s. Note: pwpsv10000229en.exe is a single file installer and does not require extraction, just "Run as Administrator".
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • lilsweepr
      0 Offline lilsweepr Wed, Jun 17 2020 1:01 PM in reply to Todd Combs
      i did confirm that running pwpsv10000229en.exe as administrator isntalled without error.
      Funny how things work correctly when done as intended huh? lol
      thanks for the help. i will pass this info along to another that will be doing similar installs in other locations.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • lilsweepr
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
