Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Publishing Forum Projectwise: How to export a list of files being used as reference in Microstation?
    • Sign In
    • State Suggested Answer
    • Replies 3 replies
    • Answers 2 answers
    • Subscribers 8 subscribers
    • Views 1409 views
    • Users 0 members are here
    • Projectwise Explorer
    • MicroStation
    • ProjectWise
    Federico Arroyo
    Federico Arroyo over 2 years ago
    Hello everyone!
    I'm looking for a way of coming up with a list of all files being referenced by files on a certain directory (and it's subdirectories).
    To illustrate: say I have a folder in PW containing several subfolders which contain several Microstation (DGN) files. Most of these DGN files contain references from other files in separate directories. Is there a way of obtaining a list of all these files that are being referenced?
    I'm using Microstation CONNECT and Projectwise explorer 10
    Thanks a lot
    Best regards
    • Sign in to reply
    • Cancel
    • Dan Williams
      0 Offline Dan Williams Wed, Mar 3 2021 12:20 PM
      Federico,
      Have you considered using PWPS_DAB?  You can find more information about it in the ProjectWise PowerShell Extensions Forum.
      Here's what is available related to reference files:
      You might take a look at this approach:
      Get-PWReferenceReportForFolder -FolderPath 'dww\Test Folder 03' -OutputFilePath 'c:\temp\ReferencesTestFolder03.xlsx'
      And here's peek at the output file:
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Federico Arroyo
      0 Federico Arroyo Thu, Mar 4 2021 2:45 AM in reply to Dan Williams
      Dear Dan,
      Thanks for the reply. Unfortunately I do not have access to PW Power Shell Extensions. Is there another way of achieveng my goal or even circumventing this limitation?
      Best regards
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dan Williams
      0 Offline Dan Williams Thu, Mar 4 2021 12:04 PM in reply to Federico Arroyo
      I was about to reply with "not that I am aware of", but then I remembered "Dave's Reports" which is included in MostOfDavesTools.
      I don't know what each of those reports actually produce, but it is probably worth a look.
      You can find the installer for MostOfDavesTools here:
      https://pwstorageazure.blob.core.windows.net/public/MostOfDavesTools.zip
      Note that MostOfDavesTools is available with the same disclaimer as for PWPS_DAB:
      VERY IMPORTANT NOTE: This set of tools is not covered under your SELECT Agreement and is not supported via your contractual support channels. Support is only available from the community of users via the BE Communities site.
      Perhaps someone else has found some other way to get the information that you want?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
