Hello, we have trouble printing pdf from Autocad definded layout – it always changes the predefined format (A4) to something else (reduces the size).
This is how the Layout (named “Format A4” in Autocad is set up:
This is how I load it to the InterPlot Organizer:
And this is how the “properties” dialogue looks like:
According to this I would think the generated PDF should have A4 format size (297*210mm). But when I generate the PDG with those settings, the final file is smaller (see the dimensions):
How do I set the Interplot organizer to generate the exact size of the layout?
Thanks!
Hello David,
Can you please check the Print Server Properties on Devices and Printer to check if the Form size is present on it. It should be exact same name present on this. If not, please add in and test the output and let us know the results.
Mohit
