Good afternoon.
We have started to rollout ProjectWise365 and ProjectWise Drive.
I have ProjectWise Drive Version 2021.3.283.0 installed on my PC and are also making use of MS Edge that is fully updated.
We have 552 work areas under one connected project.
We are experiencing the following problem.
When I shutdown the ProjectWise Drive and open a fresh instance of the ProjectWise365 portal via the browser, I am able to check out and open documents without any problems.
We have all the latest software as required by Bentley on the PWI and WSG servers.
I would appreciate any input or suggestions to this regard.
Thank you kindly and have a blessed day.
Johan
