Hi Team ,
what is the best way to select more than one file from DWG while using Projectwise autocad integration to publish it all, instead of selecting one by one, thanks
Is there a reason you can't use Sheet Set Manager from AutoCAD?
There is a forum dedicated to ProjectWise Publishing where they may be better able to answer your questions.
MaryB
Microstation 08.11.09.919Power GeoPak 08.11.09.918Power InRoads 08.11.09.918
Hi Youseff, what version of PW Explorer and what version of AutoCAD are you running?
