Hi there,
Q. Why can't I overwrite a PDF in this ‘Plots’ version Projectwise folder from within MicroStation? Refer to snap shot below:
Thanking you in advance
Rob
I am running into this issue, as well. Has Bentley figured out a solution to this problem? It is insane to think that this problem was brought up over a decade ago and there isn't a better solution than saving the pdf outside of PW and then drag/dropping it back into PW.
hello! is this ever going to be fixed?
It's fixed in Connect. Using the pdf.pltcfg that ships with MicroStation Connect Update 16.2, it asked me i wanted to overwrite the existing file and when I said yes, it did.
Testing in MicroStation SS10 it gave me the old error.
This is with ProjectWise Explorer 10.00.03.453
