Hi all,
I got a question concerning extraction for base plate location (anchor plan). Due to the actual position of the plant the models are rotated some degrees from the X-Axis.
Extraction of plan views at different elevation they come out perpendicular to X-Axis but when it come to Anchor Plan (only), the result is the following (see image below).
Please advise.
Enzo
Roger,
This model has only the column and base plates, if you know the description txt and the detail style let me know.
Regards.
SX-DGA.dwg
Hi Enzo,
Is the 2D drawing you would want to get is like what I have on the Screenshot?
What I used is the SX_002_BOTTOM view and then just added some additional lines to connect the grids.
