Can't create ISM repository from ProStructures
I'm Trying to create an ISM repository from ProStructures v8i. When I select "Create new Repository" it load all the data but after I click on the "Accept" button on the Maping Section window it just stoped working and the ISM interface doesn't show up.
I've tried by clicking on "cancel" instead of "accept" and the ISM interface appear and works as usual. The problem is that I need to create the ism file with all the section data and if I press Cancel it doesn't load all the information and I have just a wireframe model for my repository.
I've followed the steps from this video:
Hope you can help me.
Thank you
