Good day all,
I need to export a model from prostructures into SACS. Where can I get help on doing this-and also, is it possible?
Thanks in advance
Steve
Hi Steve,
Thanks for the prompt response.
I have tried this already-perhaps I should have stated this right off the bat. I was able to export the model, but importing into SACS is where the issue is. There is no import of member sections or groups. This is where the issue lies.....
Hi Steve,Drawing1.dwg
I am using SACS 5.5 The sample file is attached. Thanks in advance
