Hi,I am in the process of experimenting with ProSteel's ability to add contour marking (for cleat/stiffener/etc) locations in the shape's DSTV .NC files.I have found a few limitations and am looking for other user's feedback & experience on this topic.So far I have found:1. For channel members (PFC) contour marking can only be displayed for items located/welded to the back of the channel web or onto the outside flanges. Any items welding to the inside of the channel web, will not have contour marking displayed.2. For channel members (PFC) contour marking, for items welded to the back of the channel web, will also be displayed on the inside of the channel web.3. Contour marking cannot differentiate between different groups/assemblies. For example, you could have 2x groups (B1001 & B1002) both with the same fitting for the main part (f1001). Let's say that B1001 has stiffener's welded to it, and B1002 is a single shaft. The .NC file contour marking for f1001 will only show the state of 1 of the assemblies. It could possibly represent B1001 or B1002. Hard to explain, sorry.4. Contour marking cannot be shown for inside unequal angle shapes.Has anyone else found any other limitations to the DSTV contour marking?I need to explain all of this to the fabricator.Thanks for any help.
There are several improvements to the contour marking in ProStructuresSeries8, See NC Data
http://communities.bentley.com/products/structural/drafting___detailing/w/structural_drafting_and_detailing__wiki/28429.what-s-new-in-prostructures-v8i-selectseries-8-08-11-14-195
Point Three
There is a Makro
Overtake Group number in Mainpart number, that solves the issue with different contours of Subpart marking
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
AutoCAD 2017 - N 402.0.0 SP1.2ProSteel S6 - 08.11.11.207Australian LocalisationWindows 10 64bit
Its not necessary to switch, just one can use PowerProStructure parallel, to create the Data, in this case.
So for several cases, it could be useful to have this output capacity, not only for NC.
