Is there a way to set Bar Mark numbering to start at 01 for each bar dia. ? Could this be set in the Bar Mark Macro?
We typically group our bars per dia. in our bar bending schedule so this would enable this to produce our bar scheduling.
This is not implemented yet, an enhancement will be filed according to your request
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Thanks Johannes. Once filed how long does it usually take to get implemented?
Nicole Joyal
Bridges & Highway Structures
Manitoba Infrastructure
Canada
Hi Johannes,
we're are still wondering where this is as at?. We are now running Connect Edition 3 and this we can see is still not functioning as we would like to see as described.
Hi Nicole,
Can you please try with the Sort order options to get your result?
Also it would be nice, if you can share your requirement with your lst file so that we can look into this.
Regards,Sandip KarProduct Engineer - Bentley Systems
Thanks for the info Sandip.
However I used 2 different settings: Barmark Sequence,Bar Size, Length and then Bamark, Bar Size, Length
and saw no difference on the sorting. What is the difference between Barmark sequence & Barmark
We would like to see Barmark numbering to reset to 01 for each bar size (dia) if possible.
There's no setting for Bar size,Barmark,Length in the pick list for Sorting.
I tried using the formula for the Sort Order as shown below.
But then I get an error message missing sort order.
