保存设置之后,再次打开PS,还是之前的设置。比如我设置了单位为mm,再次打开就会出现这个框,然后单位又变回以前的了
Please, would you be so kind to post Chinese questions in
Chinafirst Communities中国优先社区PS板块链接:
https://communities.bentley.com/communities/other_communities/chinafirst/f/prostructures
many thanks !
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
