Where I can find this function in PS Connection edition?
https://www.youtube.com/watch?v=eeDOasG5rvY
I want use this function or Loft to modeling the concrete in this picture
Hi Hoa,
We just want to inform you that Template Driven Solid is removed from the Connect Edition. However we have the better tool than that.
In Connect edition there will be self definable parametric elements you can reuse and build up for your needs. Also there is the Component Center Catalog which is already available for Connect Edition products. All of those you can get in the Modeling Workflow Ribbon. See the below image for more clarity. you can go through all these tools.
How this functions in detail will be provided in the future in ProStructure is to be seen. We recommend you to have a regular look on Communities. You can also go through the What's New page for CONNECT Edition.
https://communities.bentley.com/products/prostructures/w/structural_drafting_and_detailing__wiki/37968/what-s-new
You can get better clarification and hope this will help you more to know in detail about this new release.
Regards,Sandip Kar
Regards,Sandip KarProduct Engineer - Bentley Systems
Thank Sandip,
I will try it and comment on forum. I have one more question, how I can place one block 2d perpendicular with my curves as below
You can make it by using Solids Modeling.In there is a tool at R3 ( Solid by Extrusion along).
We hope this will help you to make this kind of shape. But please note that it will not work if along the line the shape intersects with the shape itself.
We have attached here a short video which will give you clear idea on this.Regards,Sandip Kar
Hi Sandip,
Thank you so much, I just try it. but maybe it not perpendicular with patch.
And for this solid which command will use to modeling rebar?
My video: https://mega.nz/#!p0ZBSKAZ!3hUa2P1vVQubpVLrlp6S2fweIJGIhtMxCHktmvWmDw0
