Stirrup Tie varying size?
In ProConcrete how would you get the stirrup ties around the horizontal rebars where the depth changes size, for example the stirrups at the Ends of the Pier head to the middle section each get larger as the move toward the middle.  Is this a custom stirrup for each one or is there a way to make the bars follow and fit around construction lines or other bars?
Parents Reply Children
