Im generating some DVs and annotating with the 2d Rebar tool set.
Im able to customise and change the size of text for drawing annotations before creating a DV with the Text Default tools, but I cant seem to be able to change an already annotated model drawing.
Is there a way to do this?
regards
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip,
My version is V8i Select Series 8.
Im using the modify rebar tool in 2D and I can edit and change the annotations but what im after is the ability to change the text size of all previous annotations in a drawing. The only way I was able is using the Text defaults tool from the 2D rebar and set the text to a different size and then create a new drawing with this settings from the DV, but this workflow I need to re do all the annotations again.
Gilberto
Thanks Sandip I will try this.
Also do you know where I can get the correct full list for the 2D Label Text Presets?
The help file I have shows superseded variables like &bn for bar mark.
Thanks again
