2D Rebar - Bar Mark annotations shows as zero always
I get proper rebar marks in the BBS but 2D drawing annotation doesn't pick up any data.
Im using this presets but none works.
$bn - bar mark number including range variation e.g., 26(a-g)
$bnb - Bar mark number for first bar in a varying range e.g., 26a
$bne - Bar mark number for last bar in a varying range e.g., 26g
$bnx - Bar mark number excluding range variation e.g., 26
thank you
regards
Regards,Sandip KarProduct Engineer - Bentley Systems
Hello Gilberto Pires,
$bn presets are discontinued in ProStructures version.
Please find the correct presets below,
# $kl - If positioned, $kl is the bar mark. If not positioned, $kl is total length of bar
# $klb - Bar mark number for first bar in a varying range e.g., 26a.
# $kle - Bar mark number for last bar in a varying range e.g., 26g.
# $ql - Scheduled total bar length# - $ql~a, $ql~b, $ql~c ... etc. retrieves the scheduled length of# the scheduled dimension given by the letter that appears after the ~
# $qlb - Scheduled total length of first bar in a varying bar range - ~a, ~b etc. can be added for specific bar dimensions
# $qle - Scheduled total length of last bar in a varying bar range - ~a, ~b etc. can be added for specific bar dimensions
Thanks & Regards,
Nitin Chaudhari
Senior Software Quality Analyst.
Bentley Systems India Pvt. Ltd
Pune-411013
E-mail : Nitin.chaudhari@bentley.com
Answer Verified By: Gilberto Pires
Hi Sandip,
My version is V8i Select Series 8, sorry for not mention it previously.
Many thanks Nitin.
The help file in my prostructures doesn't seem to be updated
