I am placing reinforcing using the Single Rebarset placement tool. Once I have placed thebars in the correct location I save and exit out of the command. When I exit the file and re-open it I notice that the reinforcing bar's cover have changed automatically to the outside of the concrete.
Is this because of the method of placement?
I have attached a video of my procedure and what happens once I re-open the file.
Hi Jeff,
Can you please share the Concrete dgn file.
Regards,Sandip KarProduct Engineer - Bentley Systems
Abutment Concrete.dgn
Can you please try to place Rebar using Polygon instead of selecting points?I believe this workaround will work for you.
Yes, the place rebar using polygon works ok. I have tested it.
Will place by points work in a later version?
Answer Verified By: Jeff Gabriele
