Hello again
After exporting our model to an IFC file and open it i.e. on Revit software all round cut outs and circle openings on walls and slabs are shown as a polygonal cut outs and openings.
Our question is if there is a way to solve this problem or if this is normal when opening the file on a different software as Revit.
We had the same problem on Microstation V8i exporting dgn files to dwg files and opening them on Autocad all circles become polygonal objects
Thank you in advance for any help
Carlos Moura
Hello Carlos Moura,
Thanks for posting your query in Bentley Community Forum.Can you please share one example file so that we can investigate this issue.
Regards,Sandip KarProduct Engineer - Bentley Systems
Hello again Sandip
Thank you for your reply
I am sending you a sample file of some walls of a model with round cutouts.
I am sending the dgn file and the ifc file of the same objects where you can see that the circular parts in the dgn file turn to polygonal in the ifc file
Thank for your help
Best regards
Carlos MouraPHC_Walls.dgnPHC_Walls.ifc
