currently using ProStructures Connect Edition Update 1 Version 10.01.00.23.
I would like to right justify the mass column in our *.lst file.
Could not find were to modify in my *.lst using the programs Designer tools.
normally its sufficient to double click in the table in the view of the editor, when the editor is open, and look for the datafields in the data line column.
Here a similar explanation for the editing of an lst file.
https://communities.bentley.com/products/prostructures/f/prostructures-forum/151410/steel-material-overall-summary/455511#455511
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Johannes,
I found were to modify the justification for my mass column to be right justified.
Thks anyways.
Nicole Joyal
Bridges & Highway Structures
Manitoba Infrastructure
Canada
