I have created a bunch of new shapes that we use on a regular basis that did not come loaded with Bentley CONNECT Edition. Once the shapes were created I noticed that a lot of the text and dimensions of the shapes are not visible on the diagrams because the text is on top of other text or not in the correct position that we would like to show it.
I found a way to position the letters in the bar shape management area. Is there a way to position the dimension lines or add more dimensions?
for example, in the photo that I have attached is it possible to move dimension line K1 up above the rebar lines? The text K1 moves but the dimension line does not follow.
Regards,Sandip KarProduct Engineer - Bentley Systems
Do you need a copy of the .dgn file?
Hi Jeff,
Please send us your RSF file and the partlist mdb file.
Hi Sandip, I will E-mail you the files.
Thank you
We have further investigated and found there is no workaround available to achieve your result. This is a valid request and thank you very much for raising this request. There should be option available to adjust dimension location as well. Hence we have created a Service Request # 7000917695 and reported as an Enhancement # 1029501. Also I conveyed to our Product Devetlopment team about its importance. They will work on this and will further decide how to implement
Hope this has answered you sufficiently and now onward we will communicate further via Service Request panel Thank you very much again
Answer Verified By: Jeff Gabriele
