Rebar not fit with concrete
Hi Admin,
I have some problem as below
1. when click footing do not see rebar
2.rebar not change with footing
3. can not change footing profile to circle or other profile
Pl see my video for details
https://youtu.be/_29EPq24dUg
  • Hi Hoa,
    Thanks for posting your query in Bentley Community Forum.
    Please find below our comments against your raised queries
    1. when click footing do not see rebar >> In Illustration mode, with selection of object Rebars will not be visible. So best recommended view presentation is to use Transparent- Default mode
    2. rebar not change with footing >> We are not able to reproduce this issue. Can you please confirm your Version of proStructures? Also How you place the rebar in that footing? Was it placed via Pad Footing Reinforcement or via other rebar placement tool?
    3. can not change footing profile to circle or other profile >> In our current Footing tool, there is no option to place circular footing. We will talk to our development team if it can be enhanced. If you need circular footing, you can create Circular slab in MS solid and then you can reinforce via Irregular Dispatch Reinforcing.
    I hope your all queries are answered sufficiently. If you need more clarity, do let me know.
    Thank you.
    Sandip Kar
    Product Engineer - Bentley Systems
  • Thanks Sandip Kar,
    I use ProStructures Connect Edittion, I place reinforcement by component Pad footing reinforcement. Pl check my file
    Sample beam.dgn
  • Hi Hoa,
    We have tested your model, but not able to reproduce the issue. Are you using the initial release of CONNECT Edition (10.00.00.74). if so then request you to upgrade to latest Version of Update 2 (10.02.00.20). I have also attached one short video captured on your model.
    Sandip Kar
  • Hi,
    I using PS 10.02.00.20
    I just check it not work fine
    Hoa
  • Hi Hoa,
    Can you please refresh your rebarcode using Key in "Proconcrete manage refreshcodes".
    I hope it should work then.
    Looking forward to your update.
    Sandip Kar
    Sandip Kar
