If the Prosteel can make a Longitudinal Slots on profiles easy.
So far, I make a slot sketch, but can only make a square hole.
Hello long jun Deng,
We have the option to create Slotted holes in Drill command
You can provide Slot length at the dedicated box in the dialog which will give you the Slot.I hope you are looking for that and will resolve your issue. You can also refer the following Wiki Link.prosteel drill command
Please do let us know, if you need further assistance.
Regards,Sandip KarProduct Engineer - Bentley Systems
Answer Verified By: Long Jun Deng
Hi Sandip,
Thanks for your reply.
It seems this is not work. I cannot fill length in the box, it is grey.
And what we need is not standard thread hole, only some slot holes.
Hi Long,
We got the triggering point which is restricting to input data into the Slot Length box. Please uncheck 'Crete Threaded Hole" Option.
One should not have threaded holes in slotted holes. Workloose is taken care by threads.
HI Sandip,
Yes, your correct.
Thanks for your patient.
Now we can add the slot but there is no hole.
Switch to Wireframe or Transparent mode. You should see the Hole in full depth of thickness. I believe you are now in Illustration mode.
Can not we make a real hole?
And it will be become very slow when there are too much holes.
In PS Properties you need to switch to Real Holes or in Global PS Options can switch to Real holes so that always you can get the holes as real.
Thanks so much.
It works.
Question solved
