我现在在做工业建筑中的通廊,一个通廊中有好几个相同的桁架,但是这些桁架并不好选中进行复制,如何快速选中相同的桁架?
如果您想在模型中的许多地方使用特殊的桁架组件,我建议您将所选的桁架保存为模板。通过这种方式,您可以在模型中的需求的许多位置调用相同的桁架设置。 1)在“桁架”对话框中,设置所有参数 2)在“模板”选项中,创建一个新文件夹,并将当前的Truss保存为新模板 3)之后,无论何时在模型中你都需要这个桁架,你可以使用桁架命令并从模板管理器中调用这些设置
此外,您可以参考以下Wiki链接以供参考创建一个桁架 -
How to create a Truss Product(s): ProStructures Version(s): CONNECT Edition (10.XX.00.XX) Environment: N/A Area: Steel Subarea: Structural Objects Original Author: Alistair Lobo, Bentley… Last edited 3 months ago in ProStructures > ProStructures Wiki
问候, Alistair Lobo
Hello Zhang Wenchao,
If you want to use a perticular Truss assembly at many places in your model, I suggest you to save the Truss of your choice as a template. In this way, you can recall the same Truss settings at many places of your requirement in the model.
1) In the Truss dialog box, set all the parameters2) In the Templates option, create a new folder, and save the current Truss as a new template3) Later, wherever in the model you need this Truss, you can use the Truss command and recall these settings from the Template managerAlso, you can refer the below Wiki link for assistance on how to create a Truss -
您这种是屋架呀,平行的这种桁架怎么做呀?
要创建平行桁架,您只需要为Roof角度设置零值。然后将其另存为模板以满足进一步的要求。
问候,
Alistair Lobo
