Good afternoon,
I have created a shape 25 (standee) rebar, however, when positioning Prostructures doesn't recognize the shape. Have I created the rebar incorrectly?
Thank you for any available assistance.
Using ProStructures V8i PowerProduct SELECTseries 8
Version: 08.11.14.343
3414.TEST.dgn
Regards,Sandip KarProduct Engineer - Bentley Systems
Good morning Sandip,
The version of ProStructures we are using is:ProStructures V8i PowerProduct SELECT series 8, Version: 08.11.14.343
Here is the model: 2642.TEST.dgn
When I try to upload the .rsf file I receive the following error:
I will attempt to send you the .rsf file from email.
Thanks again.
Rick Erickson
Detailer | The City Rebar, Inc. | 620 Klimstra Ct, Morrison, IL 61270 | Ph: 815-772-3366| Website: http://www.thecityrebar.com/
CONFIDENTIALITY NOTICE
This e-mail contains confidential information which is the property of The City Rebar, Inc, intended only for the use of the intended recipient(s). Unauthorized use or disclosure of this information is prohibited. If you are not an intended recipient, please immediately notify The City Rebar, Inc and destroy any copies of this email. Receipt of this e-mail shall not be deemed a waiver by The City Rebar, Inc of any of its legal rights or the confidential nature of the information
Hi Rick,
I have tested your file and able to get the Partlist with the managed shape. When you got the Shape 25 with "***" just double click and then manage the Shape. I have attached a document which may resolve your problem.
If still you face issue then run Key - in "mdl command pc_manage_rsf" which will reload your Rebar Shape File.
Also please share your RSF file in my email as still I have not received the file.
Answer Verified By: Rick Erickson
Sandip,
Thank you for your assistance. The document helped to explain the proceedure.
