Can you help me solve this problem?About the projection lines below the railingsHow to remove or eliminate?This problem has seriously affected the drawing problem of our design.。
used OBD update5, We can see this promblem,But in another software(OPM),We see that ,About the projection lines below the railingsHow to remove or eliminate?This problem has seriously affected the drawing problem of our design.。
This lines should be on a specific layer you can hide and freeze. Please also attach your drawing for further investigation from our side.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
it could be also visible edge setting
hailing.dgn I tried again and found that the setting of visual edge is not the cause of the problem. In the attached figure, one chooses the visual edge and the other chooses the visual edge. The result is the same.Attached is the picture I drew with OBD update5. You open it with OPM CE. Is it bottom cable? There are two problems caused by projection lines. One is that it is impossible to export drawings in other formats, Another problem is too laggy graphics, which causes OPM to run very difficult, and the software system crashes.
thanks
How to chang on a specific layer that I can hide and freeze the bottom cable,can you tell me the way?
Hi Ruan,
I won't be able to fix your issue. But I did leave my comment in your original post.
Best regards,
Tuan Le
